Hayes
Hello people. I was installing a new speaker selector switch on my 350a the other day and the good news is that it was a successful venture. The bad news... I noticed a dial light out and decided to replace it and another weak one with 2 LEDs (8V) that I got for another project and didn't use, the light string is 6.3V. Anyway, everything lit up except the bulb at the far right which was a 6.3V. So I went to pop that bulb out and pulled a rookie move and didn't cut the power. My screwdriver hit the end of the fuse bulb and BAM... all lights out. There is still continuity on the light string but no power. Traced the 3 white wires from lights under to the circuit boards. attached images show where they terminate. Wire #1 has continuity. Wires 2 and 3 do not. Wire 4/5 is a jumper,white colored and also has no continuity. Outputs and speakers function. This was the first receiver that I bought back in the 70's so it's a sentimental favorite. Any help would be appreciated and keep in mind that I am a tinkerer, not a tech in any way. See pics. Thanks.
View attachment 1466483 View attachment 1466483 View attachment 1466483
