jahmadeus
I am currently working on a Sansui B-77 that has been giving me a lot of grief.
When I received the amp, the outputs on the left channel were shorted and a few nearby resistors (kR22, kR24, kR25, kR29) had smoked. One of the drivers (kQ9) had been replaced with a substitute. Everything else seemed to ohm ok.
I replaced the outputs, the blown resistors and swapped the drivers with the parts listed in the schematic (2sb528 and 2sd528). I also checked all nearby components in and out of circuit against the schematic and other (seemingly good) channel.
I then powered the amp on. Relay clicked on and the amp was running with minimal current draw.
I checked the bias next and discovered the bias on the blown channel was low (1mV instead of the 3mV it should be set to). I then tested the amp with some audio. Everything appeared to be running nicely. Low current draw, cool heatsinks, etc. The amp ran for about 20 minutes before the current draw began to slowly rise until it trips my variac (set to trip at 2A). The reading across the emittors also grew to a few hundred mV when this happened. It appears the amp goes into thermal runaway.
I have gone through the circuit with a fine tooth comb and cannot find any bad components. All voltages check good against the schematic and the other channel with the exception of one thing. The range of the bias adjustment for the previously blown channel is significantly lower than the other channel. Its bias pot adjusts the bias voltage from .7mV (ccw) to 3.3mV(cw). The other channel has a range of 1.1mV to 5mV. The adjustment pot for the bad channel needs to be set almost fully clockwise to achieve a bias of 3mV. All of the devices in the bias network have either been replaced or checked out of circuit as good. There must be something I am overlooking.
I have read that these particular amps can be hard to stabilize once they have a major failure. If there is anyone who has any insight to this particular model, I would love to hear it.
The service manual for reference.
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Sansui-B-77-Service-Manual.pdf
