bhundu
Addicted Member
Found this interesting record today. It's Japanese and the title only says Sanyo Solid State Stereo Otto. OTTO means "Orthophonic Transistorised Technical Operation". The tracks appear to be classical. In English I can see on the label Partichela, Lara, Bizet, Bach, Friedman. It's a 12" at 45rpm.
The gatefold is all in Japanese again but I can make out a diagram that explains a 100hz signal and a 10khz signal. I have researched that an Otto range of quad amps and receivers was released by Sanyo for their high end equipment. All of this leads me to believe that it's a demonstration record. What do you guys think?
I have washed and cleaned but haven't played it yet on two channel. I'm getting a rear Sansui amplifier this week so I might save it for that. It was in pretty rough condition but the vinyl came up ok. It won't be playing silently due to excessive scuffs but it's had the best vac clean I can give it and there are no deep scratches.
I'd appreciate any comments as there doesn't appear to be much info (none that I could find) on these pressings.
