So I have a friend who gave me a Scott 399 receiver in exchange for some work I did for him. This had been in his basement for who knows how long, at least 20 years is my guess.
So far:
- I got the correct tubes for all positions
- replaced a few way-off caps and resistors (but probably not all, there are a *lot* of parts on this thing.)
After this, then unit powered up (slowly, using a variac always) and produced hum and some sound using an Iphone as a source, not loud, but kinda sorta worked.
Happy with that result, I replaced selenium rectifier in the bias supply with 4 diodes.
After I did this, I was just hearing hum, now no music at all.
Thinking it was bad PS caps, I restuffed C1 and C2 caps (20 and 30uF, 450 volts for both cans)
Then I got a lot less hum, still no music output, and R172, a 160 ohm 2W power resistor (right after the rectifier tube) started smoking, so I turned it off
The 160 ohm resistor does have a hairline crack in it, but still measures within spec. I've ordered a new one in any case. I also replaced the for .1 uF Cerecaps coupling caps as read they could be an issue. However they also all read within 20% of spec.
There are total of 8 can caps on this thing(!), but I'd read that the others are usually not bad. Wondering it they also need attention
So taking one thing at a time, any guesses as why
- the 160 ohm resistor was smoking
- Not hearing any music through any inputs after replacing selenium rectifier
I'm a bit nervous about working on this thing; these are pretty rare and quite beautiful, and I don't want to destroy it.
So far:
