plbeard
I have a Scott LK-48 that I have had about 6 months.
It has worked fine, but one channel in the phono stage
is dropping out. The other functions (CD, i.e.) are fine.
Is this likely a capacitor problem, or could it be a tube?
Which tube, if so?
I thought this amp had been re-habbed, but I looked inside it today
(I hadn't done this before, because it had simply sounded/ worked great)
and it looks mostly original. I hate to say this (as I will be told to replace them), but the caps are original.
All of the pre-amp tubes are Telefunkens, as a matter of trivia.
Bottom line question: "What could cause a drop out or decay in a phono-stage channel"?
Thanks,
Phillip Beard
Which tube, if so?
Thanks,
Phillip Beard
