johnblue
Okay, I've never built Amps from scratch and I have my heart set on monoblocks.
I posted before about my stancor 3311 transformers the PP resistance is 10k... but now I need some power supplies.
I'm going 807 or 1625 tubes in push pull.
I'm reading that max DC plate current for these tube types is 120mah. So do I just double that? Things add up quick if that's the case... It's going to be a pretty big traffo, but if I'll never need that maximum, I'm wondering where I stand.
How do I determine the rating for the HT voltage capability?
I'm going to shoot for about 450v to start with, but how much current is needed for a PP design with these tubes?
The heater current is straightforward, but I'm unsure of the HT current, and how it varies per application.
I know I have the front end to consider as well, and I am looking at the 807 data sheets, but I'm not exactly sure how big of a transformer I need with these tubes, and I hope to get some clarification before commiting any $.
What's the amp draw of two 807s sucking on 425v? How much extra current capability should I leave for good measure?
Thanks.
Thanks.
