I've recently acquired a SL-1710 Mk2. I've been diving through old posts and they're all from at least 3-4 years ago at minimum.
I've been scrounging around looking at parts, but before I started ordering I wanted to describe what I'm seeing and see if those who had done these repairs might have input on where to start to have the most impact with the least effort.
First, what's working:
Now for the less good:
- table spins at proper speed when arm is manually moved into position
- plays albums just fine
- speed control buttons (33/45) work to affect proper change to table speed
- variable speed dial/pot seems to be in working order
- tested auto-return switch with multi-meter, working properly
- cue motor running constantly in arm down direction when table powered on
- disassembled, found that an o-ring had already been installed to replace a missing belt
- cue button did not seem to function until both microswitches were depressed, then cue button simply stops motor, but never re-engages it
- small gear does have crack, but is surviving for the moment, i know it'll need to be replaced, looking for one of those replacements as well
- manually spun, the gears drive the lowering/raising and return of the arm as expected
- stop button seemingly non-functional
- auto-stop / return does not engage
- led for auto-stop is lit when switched on with button/switch
