SoundOfSound
Thanks for the responses so far...only I can't diagnose further because I can't open this $%#& speaker! I've removed 8 screws from the back and 10 from around the bottom woofer and neither the back of the speaker cabinet or the woofer will budge.
What now? Anyone have experience with this line from Paradigm?
Here are some crappy phone pics if that helps..
HAHAHA!!! ...I fell for that too on my 5se MKIIs ... they have that back panel glued on pretty damn good.
What I found that works is that after you take the screws out from the drivers you can take a corkscrew and carefully insert it into the screw holes and lift them out.
Be careful with the white gaskets. They are a PITA to put back in place correctly, it takes some patience.
