razpones
Member
Hi all, I have posted here a few times always to ask about some issue on a repair I am working on.
But this time am writing to help someone that might run into the same issue. As am certain that this is a problem that happens to all this units.
The Sony RCD-W1 has two trays, one is a CD player, and the other is a CDR/CDRW. For what I have researched the problem always happens to the CD player, not the CDR/CDRW. The player stops working and won't read the disc, and will flash a Disk Error on the screen, the recorder keeps playing the cds and is able to record.
The problem in the CD unit comes from bad capacitors in the CD player board. The board right under the mechanism. There are 13 surface mounted caps that aren't visible under the CD transport. All of them failed, some open. I replaced them with regular electrolytic caps that i mounted laying down. The CD came back to working and is operating normally after the recap. It is an easy fix.
Here is the service manual https://www.hifiengine.com/manual_library/sony/rcd-w1.shtml
