I just installed a new mixer and remounded some speakers. The new mixer is a allen&heath and the speakers are ev250sx with a 2 moniters and a sub. The main speakers are controlled seperate from the moniter and the sub. One moniter is pointed at a choir and the other at pulpit. I get a ringing or backfeed from the moniter pointed at the pulpit. I can turn the volume down on the moniter and it stops but if I turn the mic down on the pulpit then its hard to hear the pastor. When I turn the volume down on the moniter then the choir cannot hear. Can the moniter pointed at the pulpit cause the ringing or is there something else.
Ok, first of all, you'll need to give us more information about the setup. There are just too many variables in live sound reinforcement that can create feedback issues.
- Does each monitor have it's own channel and level control? If not, they should.
- Are the monitors on the floor, flying from the ceiling, or pole stand mounted?
- What make and model are the monitors?
- Is the ringing always present when one monitor is pointed at the pulpit, or only when someone is speaking?
- Is the pulpit mic always open throughout the entire service? How is it positioned in regards to the monitor?
- Are all mics fixed, or do you also have handhelds, walk-arounds, and lavaliers?
- What make and model mics?
- Is the issue more pronounced when someone with a lavalier speaks at the pulpit? (e.g. minister/priest)
This will give me a start at a rough visualization of the setup, and perhaps an idea or two for a resolution to your feedback issue.
I also recommend a multiple notch filter type stereo feedback eliminator for this setup, one channel dedicated to each monitor.
. . Falcon
