I have a Sound Technology 1700B that I purchased about a year ago. After a complete alignment, it is working pretty well, except that if I don't use it for a couple of months, the switches (mainly the group with Distortion, Set Level, dBm) gets very intermittent. It takes a lot of messing with them to get them to work.
I have read here that I can safely ignore the "Don't ever spray cleaner on these switches" warning labels in the unit, so I plan to go in and give them a good cleaning with Deoxit and follow up with Faderlube. Just getting the unit apart far enough to do a thorough switch cleaning is going to be quite a bit of work. I managed to get the IM Analyzer board out last night and get a good look at the switches. In the past (on cassette decks and such) I have gotten the best results by actually disassembling the switch to clean it really well. If I didn't, it was a crap shoot as to whether it would work or not when I reassembled the unit. Usually, it would be better, but not quite great if I cleaned the switches without disassembling them. But I don't see how the switches used in the 1700B come apart (if indeed they can be disassembled without destroying them). Is it worth de-soldering the switches off the PCBs? What are the odds of doing that without destroying the PCB? They look like fairly cheap PCBs, the kind that are easily damaged, and the switches are all ganged together, so many of them have to come out at the same time. It looks pretty hopeless.
Can anyone offer any suggestions on how best to get these switches cleaned well? Given the amount of work required to disassemble the unit far enough to clean the switches, I'd really like to spend the extra time to get them right the first try.
Terry
Terry
