Tube Radio
I plan on updating my DIY speakers with this woofer http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-175 to get better bass response. What I need to know is what the recommended cabinet size should be. I also had the idea of using this sub http://www.crutchfield.com/S-hPxLeY...Audio-MM2154D.html?search=15+subwoofer&tp=111 along with the woofers which would mean smaller boxes for the woofers and make it easier to extend down to 20Hz. I'm also kicking around the idea of using a plate amp on the subwoofer. What do you all think about it? Is this something I should persue or should I keep the Magnavox 12" woofers I'm currently using? If I do use a plate amp I need one about 100 watts with a built in adjustible HPF that is separately adjustible or works in conjunction with the adjustible LPF.
