Worked with a couple ideas with my 2270.
You could try these (pic at the bottom). Wire goes up and in the bottom piece, spreads out, then you screw the top piece over it, pins go into 2270 speaker holes.
BE VERY CAREFUL THAT THE TWO CONNECTORS NEVER TOUCH or POOF. The pins fit nice in the holes but they can swivel to the left and right. Something like shrinkwrap or insulated tape might do the trick.
Ultimately I found the 18 ga RS speaker wire to be the best for my app. It has just 6 or 7 stiff strands in it (not a bunch of hair like strands in some). It's stiff, twists together, fits easy into the 2270 holes and, IMO, sounds better this way.
I doubt your Heresys would benefit from the larger gauge but if you think it does, that's all that matters.
