custom10
At the risk of losing cred
TJ
TJDoes the speaker you are using as a stand dampen the output? I rarely use speakers as a speaker stand because once when I was auditioning speakers in a store someone made the point that it is best to isolate the speaker you are auditioning.
Linn used to require (probably still does) a single pair of speakers in the room when demoing any Linn gear. For those who think unused speakers have no effect on the sound I invite you to attach a scope probe to an unused speaker and monitor the output while playing music. If you must have unused speakers in the room you should at minimum short the input connectors.
Think of sympathetic vibration. A vibrating speaker cone is an AC generator.
