When I bought this SPEC 4 it had some issues - a physically cracked right channel amp board and a soft hum coming from the soft start relays. I repaired and rebuilt the amp boards and replaced the filter caps. It sounded great and seemed to work well, but the hum from the soft start relays got louder and louder over time. This was a scary job for me, but I sacked up and replaced the soft start relays. Sounded great, looked great, worked great. There was much rejoicing.
A few months later...
The amp still sounds fantastic and works reliably every time I turn it on, but I noticed something... There is a small arc inside the front soft start relay at turn on. Is this normal? I wouldn't think so, and I don't believe it was there immediately after the relay replacement. There is no audible hum or noise from the relays. Any ideas on what might be causing this and what I can do about it? Should I add small magnets to the sides of the relay case? I've retired the amp from use until I can figure out what to do.
Thanks in advance for any thoughts and help, I appreciate it.
