It looks like the driver board has been replaced with and with better one with newer parts including Russian PIO caps. The electrolytic caps look like they have been replaced also.
It looks pretty good to me. The only thing as already mentioned, is the state of the tubes. You can get some decent power tubes for around $20 to $25 each.
The driver tubes are most likely fine, and still pretty cheap also. The rectifier tube isn't that expensive either, although you want to stay away from a couple brands like JJ. I use a TAD 5AR4 rectifier, the Tungsol's are supposed to be pretty stout also. I put EH 6CA7 fat boys in my ST-70 after trying various others and really like the EH's. I bought them for around $25 each for a matched quad. If you were to get this amp, I would stick with the driver tubes it has with the adaptors.
The supply for the original driver tubes used is getting thin, expensive, and can be michrophonic. The ST-70 has more support, documentation and mods than any other tube amplifier ever made. They never went out of production. When Dynaco went belly up, others just kept making kits. Like Dynakit, Tubes4Hifi, Triode USA, etc.
I would give it a good listen, and at higher volumes also before buying.
They're easy to work on and have loads of support here on AK and elsewhere.
Here is mine I built over 10 years ago using a VTA d4iver board I use in a second system.
