Greetings, is there a way to test this module without connecting it to the main unit? Here's my story:
I got a Sanyo DCA-411, tried it with some speakers and it was working for a while then the left channel died. I thought it was something with the cables and after a few more tries everything died and there was no output on the speakers. Long story short, 411 has two STK-0050 modules, the left one was blown and pins 2 and 3 were shorted and this caused both fuses on the transformer output to blow. Found this page and decided to try and replace the STK's. I had some problems with the gerber files and I couldn't import them in PCBWay or JLCPCB, so I just made a different board and I trimmed the board size to fit 411's heatsinks.
Here's
the project on EasyEDA. I used the components that were listed on Mouser. I did my ordering at Farnell, because shipping is way cheaper. After I got PCBs from JLCPCB I build everything and checked for shorts on the collectors and did some sanity checking and everything seemed fine.
When I connected everything together and turned on the amp power meters went crazy. Jumping from 40% to 80%. If I connected 50W 8Ohm resistors to the speaker output power levels just spiked to 100% and then dropped and kept doing this indefinitely. After some debugging I figured out (smelled it actually) that R2 on the left channel is sizzling hot. Right one was ok. This was with volume turned way down and treble/bass set to zero.
My suspicion is that something else broke on the main amp board and that was the real cause for the original STK to fail. So, I wanted to check if the right channel was working as it should.
It didn't. I connected signal generator to the input of the amp. Just a modest 500Hz, 0.7V sine on the AUX input. Then I displayed input and the speaker output on the scope. Input signal was a clear sine and the output was a very noisy and slightly distorted sine. With no input signal, speaker output was also quite noisy with levels jumping up and down for a few milivolts.
I connected a small 8Ohm speaker to the output and the noise was very audible even at 0 volume. I was able to hear the test signal, but it was very noisy.
So, I need to figure out where's this noise coming from and I would like to rule out this STK replacement. If I connect pins 2 in 9 to the original power supply and pins 1 and 10 to the signal generator. Then pins 3 and 8 through a pair od 0.47Ohm 3W (this is what is used in 411) and connect this output to the scope (or a speaker) should I see and hear the amplified signal? And if everything checks out, I then can start digging around the amp board in the 411.
