They seemed to have used soft steel alloy in those bolts. Being tweaked like that made them hard to undo. If he ever had to do the job again, he may need to rethread the cylinder head.The LS family engines do have issues with those bolts breaking. Wonder if they are too tight from new, or maybe its the manifold warping when hot and pulling on them.
They were replaced with approved 10.9 graded ones.I've read there is a special torque value for those bolts to allow the iron manifold and aluminum head to slide just slightly to protect both parts from cracking. Those bolts almost always fail at some point, usually the end ones. Good idea to replace them, check on the correct torque.
My thoughts too, one should never re-use bolts that are designed to stretch, and observing the correct torque setting is obviously very important.Don't know if this is relevant, but the internal bolts (crankshaft/connecting rod caps) on a Kawasaki 1500cc engine are one time use only. They are designed to stretch a bit but only one time.
Be careful with over-torqueing!I anti-seize NGK;s all the time. I use copper anti-seize compound though and just a dab, which is all you ever need anyways.
I usually don't differ from OEM recommendations, but this is one spot where I do. First time you gall a steel thread into an aluminum bore is one time too many...
Yep, drilling the manifold holes 1/8" oversize is an old trick to deal with this problem, and most engines with aluminum heads & iron manifolds have this problem. Just do your best to properly align the manifold to the port when tightening up the bolts.There are some measures that various people claim work well, to stop this problem.
One, is that there are the aforementioned grade 10.9 bolts.
Another, is to slightly drill out the bolt holes in the manifold, to allow for a bit more manifold expansion and contraction. This will reduce the bending force on the bolts (you can see the ones in the OP are slightly bent, as well as stretched).
Regards,
Gordon.
Not a problem.Be careful with over-torqueing!
