Subwoofer Question
Illusions
VNV Nation Fan :3
EDIT: SOLVED
Hi,
I have a $15 Goodwill Find KLH ASW10-1000 [or ASW10-100C] 10" Subwoofer.
Now my Question is, The Fuse Blew on it...I don't know where to go for it...but I'll figure that out myself....
Now the real question is...with the Fuse Blown and it not turning on....
Can I use the High-Level Input/Output to use the subwoofer without the fuse or powered up?
Or do I need it to power up...I don't want to try and use a lot of speaker wire if it isn't going to do anything....is it like a Sub Amp Bypass or does it still need the sub amp powered up?
Thanks in advance!
- Niko
Unlikely it will work unpowered using the high level inputs. Those are all but certainly just attenuated inputs to the internal power amplifier.
The High level Input is just another signal input. The High Level Input is filtered for the signal only, and it's not inputting any amp/receiver wattage into the sub. It's only there for systems that don't offer preamp outputs, but still want to add a sub to the mix.
So, ya' gott'a fix the fuse issue, if you want some sub thump! :rockon:
