SX-1250 Tone control issues...
Kuch73
I have a SX1250 that I went through and recapped and upgraded the transistors based on the rebuild thread on here. Everything went great except that I now have an issue with the tone control switch. When I switch it to "ON" the right side speaker gets really loud, if I switch it to "OFF" sound goes back to normal. Is this an issue with the EQ board or something else? Anything I should check or replace based on my issues? Thanks
that is a good question, I took my time for sure, but something to check. This would be the EQ board correct?
Something to consider.
The EQ provides the regulated +-24v for the tone amp.
Make sure you have the correct voltages for those two boards.
The tone board has a ton of components and if I mess up, it’s usually on that board. If it’s not a reversed component, it’s a missed solder connection.
