nd0001
I am new to AK and to vintage receivers, but I picked up this 727 and have dove head first into the repair/restoration process. I bought this one in working condition (after a little Deoxit) but the bass/treble pots were basically stuck. So I got a couple used ones off eBay and at the same time bought a re cap kit. I first just replaced the bass/treble pots and checked DC offset and bias, made the necessary adjustments. At this point I decided I would wait on the re cap for now. after I got it back together, I hooked it up and all was working perfectly for a few minutes on the radio, then the right speaker made a pop noise and the unit went into protection. So I figured id take it apart again and go ahead on the re cap, and see if I could figure out what happened. Ultimately I found one bad transistor, Q12, on the AWH-011 amp board. After scouring AK I decided on a replacement of KSA1220. I figured at the same time I would replace the opposite side Q11, and also Q9 and Q10 with KSC2690. I left the other transistors alone for now. I put it back together and turned it on, relay clicked on. Woohoo I fixed it! well, I went straight to DC offset again and was trying to adjust, but the meter didn't move. then I heard the relay click off again and started to smell heat. before I could test anything I got the dreaded puff of smoke from resistor 39 on the amp board. I triple checked pinout on the transistors I replaced and I'm certain they are right, did the resistor maybe get damaged from the original bad transistor? I am going to order up a new 100 ohm 1/2 watt resistor but what should I check next? thanks, sorry for the long post, just wanted to answer as many questions as possible ahead of time.
