hmm.... well I didn't expect that to happen!
after putting in the new lamps, I deoxit'd the controls -
system does not come up --
upon power, I can tell that the system is pulling power - but no lamps turn on, no functions come up --
I checked the fuses - they are all ok - I record 120V at the power switch when at OFF position when system is plugged into power -
upon turning the system power switch to ON, voltage reads 0 -- readings at the AC switched/unswitched plugins at back of system read 120V, so it's pulling in power --
I'm not hearing the protection relay circuit ping -
should I go in there and see what state the protection relay is in? Coming from a cold powered off state, should the relay be open or closed?
I believe the normal sound I hear on power up is the relay magnetically snapping closed, right?
The only non standard thing I can think of, is I used a 6V battery to test the lamps as I was installing them into the system - did this cause damage?
Bewitched, bothered, and bewildered am I
