Hello everyone, I have a sx-780 that i have been working on for some time.I am at the point where i don't know what to try next. At first the protection relay would not click so i replaced the stk0050 modules with new ones. Still no click I checked the voltages at the module pins and had some bad readings. i removed the modules and checked the voltages at the module pin location and here's what i found pin#1=-40.5v pin#2=-41.0 pin#3=0.0 pin#8=0.0 pin#9=41.0 pin#10=41.0 these are on the right side. the left side read pin#1=.004v pin#2=-41.0 pin#3=0.0 pin#8=0.0 pin#9=41.0 pin#10=40.0 I dont know if you can get good readings with the modules removed like this but I was afraid that I would fry my new modules. Also with the modules removed the protection will click in. I have resoldered Q25, Q19 and Q20. I replaced Q12 q14 and q15 with transistors from another board and still the same voltages It is unknown if transistors i installed are any good. Does anyone have any ideas why my voltages are so high on pin 1 on the right side? any help would be greatly appreciated. Thanks , Bill
