Thanks for all the good info. I will check it out when I have some time. Its not that big of a deal since I doubt the tuner will get much use anyway. I am fairly certain that all the caps are installed correctly. I will double check that too. I re-caped the power supply, protection board, eq amp, control amp, mic board and the power amp. I replaced all the known problematic transistors and regreased the outputs while I was at it. I did not touch the tuner.
