Kim Beneteau
I've recapped all boards except for the tuner. On the bench I'm running a couple of mini JBL surround speakers to check for sound L/R operation. All seemed good, dragged it upstairs and hooked up to a pair of Infinity P363's and good clear sound. However, it seemed odd that as I turned up the volume it kind of flattened out about halfway to max. Didn't seem to have the volume or punch I would expect but still good clean sound. Did a check of the output and measured at max volume and measured 2.55 volts VRMS with a 1khz signal with an 8.2 ohm load....if I'm calculating correctly it's only putting out about 32 watts/channel where it should be pushing upwards of 110 watts/channel. I think it's in the Power Amp but it's common to both Left and Right channels...no difference between the two. Voltages at the numbered pins on the Power Amp Board are all in the ball park. Not sure where to look next?
