Webserfer
Sorry for long hiatus, holidays and stuff and forgetting I posted here
Thank, I was going to use sewing machine oil I got but it seemed a bit too fluid so I'll look for some lithium grease when I can get to the hardware store. The pinch roller is in not as good condition as I thought but still pretty good condition, tape track looks good on it at least.
Unless you count rewind unfortunately this is a one direction tape deck :/ Would make switching sides easier.
I've actually had it for a few years now.....years, dam time goes fast, I looked at it a bit when I got it, then put it on my shelf and didn't use it till recently which sucks as its awesome. Playback is great and even filtered through a line in on my pc and only using tapes that came with it (no blanks to test yet) still sounds sweet. The tape heads have seen better days though, their not damaged as far as I can see and the tape path is clear just a bit of corrosion on the sides I have to take care of.
Thanks to everyone who's been giving advice.
You have an A-2300S. I have the later A-2300SX. There is also an SD with Dolby and an auto reverse SR. They're all wonderful machines that were built to last.
The sticky pinch roller is a common problem with these TEACs. A greased shaft runs through a tube and the grease has turned to glue over the years. The solution is to clean off the old grease and replace it with fresh grease. I use mineral spirits (paint thinner) to clean it and apply white lithium grease. I've done four of them, but it's been too long for me to tell you from memory how to get to the shaft. I do remember removing the flywheel and moving a brake solenoid. I always replace the belts while I'm in there.
Check your pinch roller carefully before replacing it. I've never found it necessary to replace one.
I also have a 3300SR, a 3300SX2T and a 4070G. Obviously, Ilike TEACs,
DKirk's advice is good. You can probably get by with the pinch roller you've got, but you may as well dump the old belt and put in a new one when you get around to doing the lubrication. Even with postage they're not prohibitively expensive. You have to take the old belt off anyway, just to get the flywheel out of the deck, and those belts need periodic replacement.
You say you have a sticky pinch roller. While your deck's working, maybe you can just enjoy getting music out of it for a while, that's certainly what I did. But sooner or later, that sticky roller is going to give you problems in playback and recording. Very likely the first thing you'll notice is trouble in the reverse playback direction, with the tape sliding sideways off the head, and there goes your audio. At that point, you'll have a one-direction deck. That would be a good time to lubricate if you haven't got around to it already.
To be honest though, I'd suggest playing with your new deck for a few weeks, and then doing what needs to be done rather than putting it off for too long. But be aware that doing it for the first time, if you're taking it slowly, following the service manual, posting a question or two - and possibly realizing you need to go out and buy this or that tool - it could well take you more than a weekend, so you'll want to have a way to keep the removed parts safe between the times when you can get back to working on it.
