I'm not going to look through all the previous threads, although from this page it seems I've missed out on some 'fun'. It's amazing how worked up people become when discussing who/what they believe to be better/best.....
(Background: Not an audiophile - the only significant differences I can determine between systems come from 1. speakers, 2. speaker/room configuration, 3. cartridge / stylus combination, in that order, all the rest - unless the TT has tracking issues or significant rumble, wow, flutter - is, for me, literally, lost in the noise!. Most cd players and amps sound virtually the same to me, provided they're not right at the bottom of the barrel).
Set one of these up this week. Piece of cake. Worked right off the bat. Then spent a bit of time tuning the anti-skate, etc. to optimum. Result: Very good value. I wouldn't hesitate to recommend this as a starter table to someone who doesn't want to fool with tuning up a vintage table. Yes, you'll get a 'better' table for the same outlay if you select a good vintage option, but unless you're experienced at tuning up an old TT it's unlikely the sound will be any better, and it could very well be worse.
Extremely low rumble... (I have test LP's I use for set-up/evaluation). Adequate tracking/compliance (didn't like high volume mixed steady tones, but then only the best can handle some of my test tracks). Good separation and soundstage, no discernible distortion or fluttering (piano, flute, tuba, organ, etc.). Tracked and played the end of Stravinsky's Firebird just fine and Steely Dan sounds great! Tone-arm is basic but the sounds generated work for me. There's no doubt that a different cartridge and stylus would be an improvement, also I used its inbuilt phono pre-amp as my current set up - Acurus DIA100 into JR149's with a B&W Acoustitune sub-woofer - doesn't have phono input. I'll do some testing over the next couple of weeks with different cartridges and a phono-equipped pre-amp. Reliability? We'll see.
So, I'm not saying this is 'better' than the alternatives. But it works well, is easy to set up, and looks better than average (high WAF).
