LutherG1
OK - Neuro tech limited cognition here but trying to make simple fix and running through possibilities. I have an SL 1650 and notice modest wobble. Not sure it really affects playback but visually noticeable and bothers me. I tried removing platter and seeing if spindle area needs tightening - not that I could see. Maybe platter itself is issue but hunch is not. I have noticed that bottom base of table seems particularly loose and that pulling it up by gripping sides or pushing down on circular area where arm is seated moves platter appreciably. Is it possible to tighten the bottom base, is it desirable, if so how and might this help? My other Technics tables do not seem to have the same "give" in platter if I do this or at least to this extent. Any advice from the less mechanically challenged?
