Technics sl 1800mk2 spindle centrate
_ZoSo_
Hi this is my first post on AK forum.
I have technics sl 1800mk2 turntable, that I disasambled for power switch lube fix. It was stuck. I oppend turntable from bottom, fixed the switch put on the bottom and screw all back together. I managed to adjust suspension also. All is working great.
My mistake was that I unscrewed botom plate wich holds the motor spindle board. I screwed it and the plater seams centered in plinth. Does some mm plus or minus will affect the 15mm overhang? I read service manual that says that the goal is to center the plater in the plinth and tighten the four screws that hold spindle/motor board. What i did- I removed the plastic under platter and loosed the four screws put the platter back centered it and fliped the whole turntable holding the platter firmly and tighten the four screws.. How to know if centered like factory :)? Thank you!
