The other cause of irregular speed, besides the belt and the speed adjust pots is failed electrolytic capacitors on the speed control board. If yours wanders in speed or you occasionally notice a burst of flutter, pull out the board and replace every electrolytic capacitor. You can probably fit ones of higher voltage rating because modern electrolytics are smaller than what's in there. Be sure to double- and triple-check polarity!
I wish I could say which ones of the dozen or so electrolytic capacitors on the board are the bad actors. But I can't because on every one of these I have done (and other Panasonics and Technics, plus Kyoceras, some Garrards, some MCS, etc...), I replaced all of them because that was quicker than doing one at a time, then reassembling and testing, going to the next one, etc., etc., etc....
