Hey guys.
I’m keen to upgrade the cart on my Technics SL-BD20 and am keen on any suggestions or where to find any info. I’m a novice with this stuff so be gentle!!!!
Thanks in advance
This. Post a pic if you don't know.What cartridge is on it now?
Hey guys.
Thanks in advance
Nice post! I don’t own an SL-BD20, but if it’s a lot like other Technics P Mount decks, the entry level kind, you can adjust tracking force with a Philips head screwdriver. It’s not in the manual, and the table says you can’t adjust it—but you absolutely can. You just need a scale since you can’t zero the arm.
What you can’t adjust is antiskate—but maybe you can, too. There’s a sticker over what is probably an adjustment screw. But in the case of antiskate, there’s no scale so you’d have to find an operational way to gauge the setting. I, obviously, don’t bother.
The range of adjustability (without modification of the tonearm) is minimal. Perhaps on the order of +/- 1 gram or less. The OP is new to all this. Best to keep things simple until he is ready to start modding. Besides, there are plenty of the old T4P standard cartridges around still. Even new old stock offerings. I would much rather have an SL-BD20 than most of the newer entry level offerings on the market now. A new stylus, belt and some fresh lube on the bearing and all should be good. A great start to vinyl with a turntable that will respect your records. Heck, the tonearm even returns to its rest after the record is finished playing. Sometimes I really miss that feature. I might have to get out one of my SL-QX300s tonight.
My estimation is that the Technics P -Mounts are better performers than many new "audiophile" entry level decks as well.
Currently the tt has the p24 cartThere's a very limited choice of p-mount cartridges out nowadays. What cartridge is on it now? You may simply be able to upgrade the stylus to one with a more exotic profile.
An Ortofon p-mount may be a solution, such as an OMP or TM. You may need to buy the body secondhand but then you could select your stylus from Ortofon's OM styli, ranging from the Stylus 10 to 40. The Stylus 20 (nude elliptical) is good value.
Reviving this old thread to ask Decibel a question: what is the cheapest P Mount TT (non-linear) you'd recommend which would let me run a Grado cart? I have an SL-5, but it's finicky, very sensitive to the slightest imperfection in vinyl and won't play new, thicker pressings at all. I've wanted to add a P Mount that's more robust without breaking my beer budget.Welcome to the forum! The SL-BD20 was one of the last belt drive turntables manufactured by Technics. It employs a very ingenius cartridge mounting system by the name of T4P or "p-mount". It was supposed to standardize swapping/replacing cartridges by imposing a standard mass and a standard tracking force of 1.25 grams. To upgrade the cartridge, it is a simple matter of removing a set screw, unplugging the old cartridge, inserting the new cartridge and replacing the set screw. This system was intended to make obsolete the task of mounting the cartridge to a headshell, re-balancing the tonearm, setting the tracking force and setting the alignment of the cartridge. Unfortunately, the T4P or "p-mount" cartridge did not take off as it came about just as the compact disk (CD) was coming into it's own in the marketplace. Please be aware that some p-mount cartridges require slightly more than the standard 1.25 grams of tracking force. One example is the Grado p-mount cartridges which require 1.5 grams. The SL-BD20 does not have adjustable tracking force. There are plenty of vintage p-mount cartridges around on the auction site. The Technics cartridges are very nice and can be upgraded to a fairly high standard. There are some NOS Audio Technica cartridges on the auction site right now. There are several threads about p-mount cartridges here.
(...) what is the cheapest P Mount TT (non-linear) you'd recommend which would let me run a Grado cart? (...)
Thank you! Got a favorite? I have no idea what's worth owning.You could consider one of the models of the 1st T4P radial-tracker generation - 'cause all of these, from the SL-B10 up to the SL-Q30, still sported both tracking force and antiskating (fine-)adjustment.
Greetings from Munich!
Manfred / lini
Got a favorite?
Is that even possible?
Thank you sir! This is exactly the info I was looking for.The SL-Q20/Q30 - for being not only quartz-referenced DDs, but also more substantial than the lower-ranking models
Can't tell, whether those P-mount Grados might already track reasonably well at 1,25 g, due to having no personal experience with these. But maybe these people are aware of the trick. Shall mean, while arm of the SL-BD20 doesn't sport the counterweight variant with the thumbscrew plus scale and indicator for the tracking force (fine-)adjustment, the tracking force can nevertheless be altered. I.e., if you have a look at the rear end of the counterweight, you should be able to spot a regular screw, via which the position of the actual counterweight can be adjusted - but due to the lack of the aforementioned scale and indicator you'd need to check the adjustment with a tracking force scale instead.
Manfred / lini
