Technics SLQ 300 vs Dual 1257
tillmbil
I currently have a the Technics in one of my systems, and was wondering if the Dual 1257 would be any better. There is one for sale near me for $65 working, with a Shure 95 cartridge. I like the Technics and just purchased a new cartridge for it, but I have read a lot about the Dual tables. I also read that the 1257 is there lower end and plastic, but have never owned one so I thought I would ask.
If it would not be noticeably better than I will wait on a better deal.
THANKS
THANKS
The Technics SL-Q 300
https://www.vinylengine.com/library/technics/sl-q300.shtml
is technically more advance than the :)
Dual 1257
https://www.vinylengine.com/library/dual/cs-1257.shtml
I don't think the 1257 would let you down as far as its performance, if it's been serviced recently. I don't think it would be an improvement over the Technics, either. If you're interested in Duals, I'd look for a 1219/1229/1229Q. I like the 1209 as well, but it's got the smaller platter that may be a turn off for you!
THANKS
Noticeable better... I wouldn't want to offer that but personally I like those mechanical duals, like the way the mechanism works, even the way it sounds when indexing or returning after play. I like their tone arms too... the gimbaled tone arm support, the clockspring to apply the tracking force instead of counterweight. In terms of plastic, Technics made a whole series of turntable that were just about all plastic.... which isn't to say they weren't good... Pioneer went through a period of making many of their turntables out of plastic too. I'd get the Dual just to have the experience with a Dual. Just about anything on one of those can be fixed barring brute force damage. Obviously I like them and they have a certain German mechanical charm about them and they work quite well, very smooth and balanced mechanical functions including the controls. (assuming everything is in good order)
Due to the cartridge availability for standard mount versus p-mount.
Yeah... was thinking that along with the qualifier.... if it's set up right. One thing about P-mounts is the overhand was supposed to be standardized... don't know how that actually worked out though but it did narrow cartridge options.
Spicer
I was thinking along those lines myself. For $65 you really cannot not go wrong and I like the aesthetics. Who does not need another TT right?
Here is the cartridge and needle. I read on this Forum that the single screw mount is good, Any body know if this is a good cartridge?
That's a Shure M95 which is an excellent cartridge.
The single screw mount can actually be more of a problem than advantage as it limits you to a very narrow range of rare Ortofon/Dual cartridges. However that Shure is mounted courtesy of an adaptor that allows standard 1/2" cartridges. That's handy to have.
