Technics SU-V9 Integrated Amp
RDSChicago
Well-Known Member
I just picked up one of these on that auction site after having had many other Technics integrated amps and receivers. I have read such great things about the V9 that I jumped on it when I had the chance to find one.
Just plugged it in and all I can say is WOW! I first connected it to some high-sensitivity Focal 807w bookshelves but thought, with all of this power it would really rock my vintage Kef 105/2's. If I turn the volume knob past 9:00 my dogs get up and leave the room. Great, clean power.
Every time I turn on a great vintage amp like this one, which you can pick up for a song, I wonder why people on this site say the vintage amps can't hold a candle to the new modern technology?
I am returning two new powerful amps I purchased recently from HK and Musical Fidelity as IMHO, they don't hold a candle to this monster V9.
Here are some specs. Enjoy the music:
Form Integrated DC amplifier
<Tuner, the Aux->SP out overall characteristic>
Effective output (20Hz - 20kHz) 120W+120W (4 ohms, 0.007%)
120W+120W (8 ohms, 0.003%)
THD 0.003% (Output-power-3dB, 20Hz - 20kHz)
Power bandwidth (THD 0.02%) 5Hz - 100kHz
TIM Incapable measurement
Remains noise (straight DC) 0.7mV
Dumping factor (8ohms) 80
Load impedance main or remote: 4ohms - 16ohms
main and remote: 8ohms - 16ohms
<Other properties>
Input sensitivity/impedance Phono man month: 1.0mV, 2.5mV / 47kohm
Phono MC: 100 microvolts/100 ohm, 250 microvolts/220 ohms
Tuner, Aux, Tape:150mV /, 33kohm
Phono maximum permissible input
(1kHz, RMS, THD 0.01%) MM:170mV(2.5mV)
MC:17mV (250 microvolts)
THD Phono man month->Rec out: 0.0005% (1kHz, output 5V)
Frequency characteristic Tuner, Aux, and Tape:20Hz-20kHz+0 -0.2 dB
0.5Hz-170kHz+0 -3 dB
SN ratio Phono man month: 88dB (2.5mV input)
Phono MC: 71dB (250-microvolt input)
Tuner, AUx, Tape: 103dB
Tone control Super Bass: -0dB-+10dB (30Hz)
Bass: ±7dB (100Hz)
Treble: ±10dB (20kHz)
Turnover frequency Super Bass: 75Hz, 150Hz (12 dB/oct)
Bass:500Hz
Treble:2kHz
Light filter High: 7kHz, -6 dB/oct.
Subsonic: 20Hz-12dB / oct
Loudness control 7dB (50Hz, Volume-30dB)
Preamplifier part Output voltage (Rec out) 150mV
<Synthesis>
Power source AC100V, 50Hz/60Hz
Power consumption 205W
Dimensions Width 430x height 120x depth of 350mm
Weight 14.7kg
