Tell me something normal
TalYWaun
The concept is stolen from another of my favourite sites, but thought it might be interesting to play it here.
Last weekend I performed the yearly maintenance on my pond. This involves setting up a large paddling pool and using the pond pump to move the water from the pond into the pool. When the water level gets low I catch the fish and transfer them into the pool. Normally this takes some time as I chase them around the pond with a net. Surprisingly this year they were quite easy to catch and nowhere near as fleet of fin as usual, which I guessed was due to the water still being quite cold.
Once the fish are out it’s time to remove all the plants, rocks and features and hoover up all the old leaves, mud, etc that has settled on bottom. Luckily, as I live on a hill the pond is on the patio about 6” above the lawn so I use a pipe and let the siphon effect to do the work. Once almost all the water is out I move all the stones up the slope towards the waterfall and get to work with the pressure washer to give the stones a bit of a clean. In the deep area of the pond I have a couple of large slabs supported on bricks that the fish can go to hide. At night they line up on the slope presumably using the flow from the waterfall to wash the water over their gills. Unfortunately this also means they tend to push the stones down the slope which had obstructed the entrance to their home so that my two big fish couldn’t get under there. Lesson learned I put a bit of a retaining wall at the bottom of the slope to stop that happening again and made their home a bit taller.
So with the main job over its time to run the underwater lighting cables and the water pump pipe for the pump which is at the opposite side of the pond to the waterfall. Then spread the nice clean stones out and cover the cables and pipe and rebuild the fishes ‘home’. Using the siphon again I let that move the water from the pool back into the pond. And return the fish and plants back into their nice clean pond.
When I clean the stones I also pressure wash the statue and all the other bits, so I get to check out everything quite closely. A few days after, I noticed a toad swimming around in the pond. There used to be a big one that lived in the bottom of the statue (where there is another pump) but I haven’t seen it in a few years and so it was nice that a new one had moved in. A few nights later I saw the toad swimming around and then saw another one, so with any luck I could have family of toads in there soon. This year I will put all the spawn into a net. When that happened a few years ago I didn’t, and all the tadpoles slowly disappeared as I guess the fish (or the main pump) ate them. The only slight problem is how noisy even a little toad can be when I am trying to get to sleep, but I think I can live with that and for a while that took my mind off corona virus.
Here are my fishes having breakfast in their nice clean home. OK, it’s not big, and it’s not clever. But so what, you got somewhere else you need to be?
https://drive.google.com/file/d/1giDMA7HEJCs0lhkZGskygyY0sj5JgsZu/view?usp=sharing
On of the most normal things in the world is: greeting another person. Saying hello happens in every culture and every language.
So, HELLO!
Something normal? This 'rona hasnt really effected us that much, other than we go shopping alot less often now. Some normal everyday things I have done today:
I took the lawn tractor down to the river today to see how high the water is. Its about a KM in distance, a beautiful drive too. On the way down I noticed a huge cedar, that was lightning struck quite a while ago, had blown down another big section. So I went back and grabbed the new Stihl saw to get it out of the trail. When I got that job out of the way I noticed a few ash trees that were begging to be cut down for firewood. Dropped those and blocked up some standing deadwood for the woodstove in the days to come. In my weak condition (cancer patient) I cant do much and its frustrating as hell to not finish a job. But alas, I still got lots done. A couple of friends have promised to come help with their quads and get some wood up to the splitter for me.
We got 14 eggs today from the chickens, oh and we have 2 ducks so we got another duck egg. Part of our 185 acres lays down the road a little ways and across the road. We often have people dropping off garbage there, and stealing my trees, despite the 2 new, high vis "No Trespassing" signs prominently displayed. So I have started an off grid CCTV system. 3 solar panels, a charge controller and 2 marine batteries, all power a NVR and a router so I can see the cameras when I pull into the driveway. Not done yet but sits coming along.
Bullet the GSD got into something and cut his 2 front paws kinda bad, so hes on house arrest for a couple of weeks. We have 10 chicks in the brooding box in the kitchen and 31 more eggs in the incubator with one piping today. Should have more chicks in the next few days.
Farm life.
93404453_3231254203591890_8757986831112339456_o.jpg 93833625_3236847849699192_399922701491240960_o.jpg
Do you keep a few stones or other material "uncleaned" to kickstart the nitrogen cycle?
The nitrogen cycle? I had to look that up. So, in answer to your question is no. But, I do have a pressurised multi stage filter system that has bio blocks at the bottom. The foam filters get a good clean but the bio blocks just get a cursory wash over. Plus whist I try to get as much muck out as possible I don’t get it all as proved by the colour of the water when it gets refilled. I have also arranged my rainwater gutters so that all the water gets sent to the pond which then overflows into the main drain so the water gets refreshed when it rains. If I know a good storm is coming I will drain about a third of the water away to ensure that the proportion of fresh is increased.
OK, just wondering. I used to have several aquariums in years past. Starting a new one was always a challenge because you knew it had cycle before the fish were happy. You could short-cycle by moving something like a lava rock from an established tank to the new one.
Nice project by the way.
Well, I'm still walking the dog and working every day (teleworking, but still). And listening to music.
