I've had a few "shockers" over the years. Sometimes you forget just how fatal 600-700 volts fused at 3-4A could be, when it only takes ~50mA to stop your heart! (by the time you blow the 3A fuse through your body you are probably done for- see diagram below)
Actually the WORST shock I've ever received (at least by it's physical effect) was not a piece of audio electronics, but a distributorless ignition coil pack capable of 60,000 volts! I was setting the cam sensor timing on my Buick Grand National , turning the engine slowly with breaker bar while I watched the DVOM to go from 5V to 0V. But I had my other hand resting on the top of the coil pack and the instant the voltmeter went to zero it was "lights out"
I literally blacked-out for a few seconds and woke up sitting on the shop floor about 8 feet away! LOL Then I had a bad case of the shakes and was a bit goofy for the rest of the day. (my wife still refers to the day as the day of my "shock treatment" which apparently mellowed me out)
I went to the doctor the next day and he said would be OK but said even though there was probably not all that much current, that type of high voltage and discharged so quickly COULD put me into v-fib (especially as I had pretty much given it a path up one arm and down the other)
That was about 15 years ago but it prompted me to to take some training, read up on electrical safety practices and shore up my protocols and techniques to prevent making my kids a bunch of orphans! LOL
The human body's electrical resistance is a bit difficult to nail down as it depends on numerous factors such as your size, weight, fat and water content, skin moisture, etc but generally accepted to be ~1000-2000 ohms. So even a lower voltage tube amp with a 300V power supply is capable of 150-300mA into your body which is obviously serious depending on how the engagement takes place and you ability to break the circuit.
PLEASE STAY SAFE MY FRIENDS!!
WopOnTour
