The numbering is curious, the first number is the heater voltage center range, the last the number of active elements. The system is somewhat inconsistent on multi-section heater count, 6X4 vs 6X5, f.i.
Nonetheless, a direct heated triode would be 3 elements, indirectly heated triode a 4. Why 8?
I have two different Sansui receivers that use 25E5 B/W beam tetrode TV sweep tubes.
I've got one of those receivers, nice build quality.My only Japanese amp is a Realistic/Trio with EL84s, I think I need to get out more, or something!
If the suppressor was internally tied to cathode (as is usual) and the screen to plate, technically it's a 6RA4 triode from the outside, an otherwise unassigned designator.mentions I've seen on it elsewhere speculate that its actually a pentode, but internally triode-wired rather than being an honest to goodness 3 element triode tube. Still doesn't really explain the number though.
Four 25E5 in series light up directly from the 100 VAC line, saving stress on the power trafo.Mine is a Stereodyne 40A. It's OK. Very compact, heavy, and hot. Way worse than a Dynaco SCA35.
Bet the Sansui with the 25E5 tubes sounds pretty good when it's going.
The export versions lit them off a tap on the primary, iirc.Down side is that, is a heater to cathode short could put 100V on the chassis. I think that setup never met UL standards, or we'd probably have seen it in penny pinching US gear,
I think the Zenith porthole TV sets use some sort of similar arrangement.
Quite right!Definitely, but in a TV any accessible metal parts are isolated from line voltage, whereas in an audio amp the chassis has to be bonded to circuit/signal ground, and definitely the shield of the phono inputs has to be at signal ground or else hum would become too much of an issue.
I gave it a try and won a set of 4, let's see how it works out. Thanks!Just looked at Yahoo Buyee and there are 4 used quads of 6RA8 listed. Use Google Translate if I want to read the descriptions.
Set up an account at Yahoo Buyee so you can check it out. I have purchased used tonearms from there, so far nothing but good luck. Of course used tubes are another thing but I generally find the Japanese are pretty honest in their assessment of used parts or gear.
BillWojo
Probably not a lot of demand competition is the upside.I gave it a try and won a set of 4, let's see how it works out. Thanks!
I hope they are somewhat strong, it's a crapshoot that's for sure. I have some discussion going with Dave Gillespie on converting it at some point, can't hurt to ask as many experts as possible.Nice, hopefully having 3 spares means you have a lifetime supply now!
