All of us guys with the "A"s can be snobs now! LOL
The decks before the change aka early models are naturally more rare. Not sure if they dropped the A at some point later so there could be newer post change decks that don't have the A but are same with those marked A. Anyway, there are other clearly visible indicators about the change, main one being big (old) vs small (new) rca cables hole.So are decks without the -A the more rare decks?
KAB got back to my over the weekend and i was able to get it all up and going. Thanks KAB for the great service! FYI the info i got for posterities sake is that for the MK2 it is 3M X16mm . For the M3d,MK5 and M5G it is a phillips head drilling screws for metal, Zinc Plated steel, number 6 1/2 inch long. Fit perfectly!
Dony good chance your SL-1200Mk2 will outlast you. As per the owners manual the only routine maintenance required is a couple drops of oil ( Technics or sewing machine) at every 2,000 hour intervals and keep the table clean.
No need to say anymore, Kevin/KAB is the go to guy for just about anything Technics.
Would you happen to have a link for that doukmall brass mat? Thanks.+1 for same comments.
for all the 1200 owners as well as other TTs with a cast aluminum platter, adding the doukmall brass mat to the platter then adding the rubber mat on top makes a huge improvement in clarity.
Yes, that was my first stop in looking it up before I asked for a link. Perhaps I missed it or I'm being a being too literal but I did not see doukmall brass mat listed.
