Tone arm return issue
quadmatrix82
AK Subscriber
Hi all, hoping someone out there might be able to help, I have a JVC JL-A20 Belt Drive turntable and when the tone arm reaches the end of the record and returns back to its idle position it seems to miss the point and fall in between the platter - is there a way to adjust this so it sits properly on its idle point? hope that made sense! appreciate any help!!
Hi, I'm not familiar with that turntable but one way or another, there should be a way to adjust the arm relative to its spindle. The thing to watch is that if you alter the arm return point, you might also alter the trip point on the run-out groove. Hope this helps.
hi there, thanks for your help...i noticed a rubber stop was worn out..just replaced it and it works great now! thanks again :)
