goldwax
dozy ming-mong
Manual in hand (thanks, bobaloniny!) I took a stab at correcting the cartridge set up last night using the Stevenson method. Not sure I entirely got it because (1) I had to convert the 46mm stylus to end-of-headshell distance to inches in order to use the only ruler I had to hand and (2) I didn't quite understand the Stevenson protractor. It has two grids on it and I don't see how I can possibly get the cart to line up to both without rotating the platter. Are you supposed to rotate the platter? I'm only familiar with using a Thorens arc protractor in which you keep the platter still. Any info would be helpful.
Anyway, just getting it close to 46mm and lining it up the outer grid did help a lot. Man, but this is a sweet little table. I love the no-frills utilitarian looks of the thing, too.
