mzeitlin3348
See it and Believe
The service manual of my turntable calls for a 2SC1846-R transistor. Cross referencing listed an NTE-295.
I replaced it and my turntable stopped working where it worked before - as if little to no power. When I turned it on no strobe light and the platter barely moved. Clearly a problem.
I took a closer look at the part I removed and it wasn't a 2SC1846-R, but instead was a 2SC1846-Q. According to the cross reference, this calls for a NTE-373. This has very different specs.
Did I screw up? I went with the manual rather than the part on the board. Did I do damage or just go and replace the wrong part with the 373. Anyone else make this mistake? or is it a mistake (i.e. parts are interchangeable)
