Drivers and pre-drivers?
2SC1904A (TO-126) >150Vceo, 50mA, 1W, B=150, ft=130MHz
2SA899A (TO-126) >150Vceo, 50mA, 1W, B=150, ft=100MHz
2SD608A (TO-220) >160Vceo, 1.5A, 20W, B=80, ft=45MHz
2SB628A (TO-220) >160Vceo, 1.5A, 20W, B=80, ft=40MHz
All of these are 'A' variants, so the voltage rating should be higher than the non-A part. Anyway, the TO-220 driver is easy...use the MJE15032 and 15033 for the drivers. Personally I think these are a better choice than the 15034/35, as the high-voltage capability is not needed.
The hard choice is replacing the C1904A & A899A. A lot of good TO-126 parts went away in the last year.
Best Choice - Fairchild KSA1142 & KSC2682. Since these are damn hard to find, the Sanyo 2SA1210 and the 2SC2912 are a couple of the last decent low-current wide-bandwidth TO-126 parts left. B&D has them.
2SC1669 is too slooooooowwwwwwwwwwwww.
2SC2441 (TO-126??) has nice specs, but what's its complement? If the amp blew, you change not just the NPN, but the PNP too.
