aidynphoenix
i have been trying to understand the Mini-CMoy Pocket Amp design and use the parts i have on hand to build my own..
i have the right caps and resistors..
but im having a difficult time understanding how the layout of the op-amp works..
i have two working LM386 amp chips.. each is a 8 pin.
http://www.national.com/ds/LM/LM386.pdf
in the pocket amp that i am trying to basically reverse engineer.
http://www.tangentsoft.net/audio/cmoy-tutorial/misc/mini-cmoy-layout-0150.pdf
it is useing a dual channel opamp.
and i will be trying to use two 1channel opamps..
but i dont understand where the +9v and -9v inputs are on the opamps that i have..
i know where the audio signal inputs are. and where the Vout is..
i understand that 2 and 3 are where my audio signal inputs eventually go..
and that 5. is to the heaphone positive for either channel.
but i dont know where my power inputs go.. and also if the extra pins are unused or not...
