barberbasses
Thanks Dandy, clearly this can get a little out of hand unless you go in stages. In this case, i figure if I'm in there I may as well get some of these things cleaned up. I should have more time this weekend to get work done.You're doing a great job. Those wafer tube sockets can be pretty flaky by this stage, so replacement is good. No harm in using small bolts instead of rivets.
My only comment for your next restoration (!) is to do the electrical rebuild in stages. First just replace the can filter caps and the coupling caps to the grids of the 6BQ5 tubes and get it working. Once that's done, replace other components as needed and check that it's still working after each change.
thanks
