Hmmm, still puzzled. Here is the circuit. It's a true phase inverter stage and the "phase rev" switch switches this stage, not the speakers. Definitely not the phase inverter for the power amplifier stage, but a free standing circuit early in the signal path, just after the line inputs or the pre-amp (if it's in use).
Unlikely, unless it's some sort of esoteric circuit in that preamp. The common cathode gain stage, as is commonly used in preamps, inverts polarity as it amplifies. One signal in, one signal out, but phase inverted with respect to input. Its Just the nature of how it works. (Transistors behave he same, by the way.) Technically speaking the reason for the polarity inversion is because the "load line" for the stage has a negative slope....this is probably the kind of circuit you're talking about in your pre-amp.
I also have an 8000 and the Phase rev switch is to reverse the polarity of just one of the speaker outputs.Is this the purpose of the phase inverter/phase reverse stage/switch in the Sherwood S8000 IV? I've been wondering exactly what this circuit is for and how it affects what the amplifier is doing. The PI stage is right after the pre-amp and before the tone control amps in the circuit.
BTW, if the amps are bridged, the (theoretical ) power becomes 4x one channel or 36x4=144w. but most amps. can't produce that much power unless they have a very robust power supply.This might explain it...
The S-5000 could also be used as a mono power amp, giving 72 continuous watts. This was done by connecting the two speaker leads to the same figure (4.8 or 16) at each output channel at the rear. By using the "phase" switch at the front both amps would drive the same speaker - with double power.
So the phase switch could correct a speaker with the wires reversed, but it would also allow you to bridge the amplifier to mono operation. (It also seems to affect the REC OUT which is strange.)
well, it does but only on one channel. More importantly it changes the phase of one channel relative to the other. If both channels have an inverted absolute phase, they are still in-phase with each other and it won't sound obviously funny.Let's say you have neatly wired the system, pushed the stereo unit against the wall and then realized that the speakers are mis-polarized. Flip the switch and everything is OK again. It doesn't change the Absolute Phase.
Gadget - Something I forgot to add was that when running in Bridge mode, the speaker has to connect from Plus to Plus speaker outs.well, it does but only on one channel. More importantly it changes the phase of one channel relative to the other. If both channels have an inverted absolute phase, they are still in-phase with each other and it won't sound obviously funny.
Dunno, some amps invert, some don't. My Pilot SA-260 does. The Pilot preamp that was most commonly paired with that amp does not though. Overall you'd end up with a phase inversion from input to output. I guess if I really wanted to fix that I could simply add in an inverting zero-gain op-amp to work as a buffer but frankly I don't care all that much. If I were to add the buffer it would be to use that preamp with something that it wouldn't drive natively, and to be dead honest with you I've got better preamps that will drive lower impedance anyway.
It's not so strange if you consider the AM/FM stereocast issue, so I think that clinches gadget's argument quite nicely.So the phase switch could correct a speaker with the wires reversed, but it would also allow you to bridge the amplifier to mono operation. (It also seems to affect the REC OUT which is strange.)
