SimplerTimes
I have a Garrard DDQ-550 direct drive turntable that I picked up for cheap. As far as early ‘80’s turntables go, it seems to be a decent unit and I want to keep it as a spare. So I connected it to my Sansui G-6000 to test and it worked fine for a few moments, but as I was manually moving the tone arm and checking the auto return and speed selector, it developed a very loud hum through the right channel. I rechecked the ground wire connection to the receiver and could see no problem. The hum seemed to get better as I touched the tone arm and gimbal(?) mount area so I decided to check for an internal grounding issue. After removing the bottom cover and checking the RCA cables and ground wire for continuity to their respective solder points, all checked out ok. I also connected the Garrard to another receiver with a known good phono section as the Sansui is new to me and I wanted to eliminate it as the problem and it still hummed. It appears to me to be either a problem between where the input cables are soldered to the tone arm assembly or possibly something on the circuit board. Does anyone have an idea as to what I should check next? I have looked online for a schematic and have found nothing. Any advice would be appreciated.
Thanks,
Brian
Thanks,
Brian
