bubba ho tep
Decision made. Bid made on a nice WTRP! Now we wait. Will update progress as I hear. Thanks to everyone for helping me out with this......then its speaker choosing time.
, thanks to the constant help of John "Mister Pig", a project 6.1 with a nice cartridge. 78 speed compatible for my new beach boys 10". So it looks good. Having a pain trying to my credit/debit card verified through paypal though...so thats all that is holding up the transaction. I will update when I have more information. This will be the workhorse TT, the next one will be the vintage one I'll make over time........oh and an early 60s dansette...some 45s only sound good on one of these...I dont know why!
Congrats on your almost-purchase!Been busy sourcing a table within the budget- but after the well tempered( that I matched the price for never got back to me), the SOTA (with the humming motor, a new motor is about $600) and the pro-ject that wasnt actually still available for sale...but it was still listed...fiasco..........
I found one, thanks to the constant help of John "Mister Pig", a project 6.1 with a nice cartridge. 78 speed compatible for my new beach boys 10". So it looks good. Having a pain trying to my credit/debit card verified through paypal though...so thats all that is holding up the transaction. I will update when I have more information. This will be the workhorse TT, the next one will be the vintage one I'll make over time........oh and an early 60s dansette...some 45s only sound good on one of these...I dont know why!
I was just thinking of suggesting not worrying about having a 78 speed on your TT, but consider getting a lesser TT that runs at 78 and using that on exclusively for 78's. But maybe that (and your homebrew one being TT#3?) won't pass muster and WAF (look it up.).
The reason being that to go from playing an LP to a 78 you have to change cartridge (not a big deal if the arm has a modular/detachable headshell, like the SL-1200) or at least the stylus (usually a big deal, and even when not, you still risk breaking something expensive by moving these things around), and you ALSO need to readjust the tracking force (even with the same cartridge, a 78 stylus usually has a tracking for range higher than an LP stylus). It's easy to forget things like resetting the tracking force (don't ask how I know...).
With all that, if you can afford it both money-wise and physical space-wise, it's easier to have a second TT set up exclusively for '78's. But if you don't expect to switch between playing LP's and 78's often, this may not be that big a deal.
Actually the 78 issue can be solved quite easily with this table. The 6.1 used a plinth that is basically the same size as the platter. So it is possible to fabricate a block or pod to hold a second arm. This arm can be set up for 78's, so the speed option on the 6.1 won't be wasted. This should be cheaper than having to buy a whole second table to play these other records.
Regards
Mister Pig
:thmbsp:I found one, thanks to the constant help of John "Mister Pig", a project 6.1 with a nice cartridge.
Top idea:thmbsp:
Next Ill want three arms on the TT. One for the 78s, one for the good records, and the other for thrift store vinyl finds!...if thats possible of course
:thmbsp:
If you make your own armpods to put around the 6.1 you can go up to four arms. :thmbsp:
(table with removable headshell on the arms makes this approach a bit more out-of-the box of course)
If you're not afraid of a bit of diy here's an affordable route into the multi arm domain;
http://www.audiokarma.org/forums/showthread.php?t=363527
I've never heard of a microgroove 78, though I've played at least one Audiodisc with the "78" groove that played at 33 and 45 (and from the inside out as well as the outside in, some of these all on one record!)Oops I should of explained better. The only 78 I have at the moment in the country is The new beachboys one which is a microgroove 10",so I wouldn't need to change the cartridge for that right? The more I think about it, the more separate systems I want down the line....this could turn into a unhealthy addiction!
Though a table purely for 78s is a top notch idea.....in time perhaps I can even convince the wife....but I have to get her used to the first TurnTable first.
.........this whole process would have run so much smoother if I was a bachelor! The things we do for love....indeed:nutz:
That's a great idea! I've only seen online pics of multi-arm TT's, never one in RL, so that hadn't even crossed my mind.Actually the 78 issue can be solved quite easily with this table. The 6.1 used a plinth that is basically the same size as the platter. So it is possible to fabricate a block or pod to hold a second arm. This arm can be set up for 78's, so the speed option on the 6.1 won't be wasted. This should be cheaper than having to buy a whole second table to play these other records.
Regards
Mister Pig
Sure it is, that would be ideal. I've played lots of thrift store LP's with an original non-a AT440ML over the past 10 years, and it STILL has the stylus and STILL sounds great! No doubt running every new-to-me LP through a vacuum RCM helps a lot.Top idea:thmbsp:
