Does anyone recognize these 12" woofers ? Numbers on the magnet are L12PN.21110070-90-1 the bottom number is 060530 Same numbers on both speakers. Cast Frame
Thanks for the fast response. I'm learning a lot as I go. Am I to assume that we can use Google with just the numbers and get an answer? I may not have to bother everyone again
Sometimes Google will give nothing for the numbers, but if you can read EIA codes, often there is a 3-digit manuf. code and a date code embedded. At least for older stuff - more recently it doesn't always work.
