Hey guys, so I've got a pair of AR TSW-410's that I want to recap. The problem is, the crossovers are glued to a thin board, which is glued to the inside of the cabinet, and the posts run through all of it and are soldered to the back of the PCB. Long story short, it's a real pain to get it all off.
I was wondering if it would be inadvisable to forgo the hassle of removing the crossover entirely, and instead, leave it attached and de-solder the old caps, remove them, then insert and solder the new caps, while leaving the board assembly intact.
I know that the crossovers are wired in the orientation circled in the photo, and once I removed them, I could figure out exactly which is which and solder in the new ones.
One problem I can imagine is physically getting the caps into the right place, I'm thinking I'd be able to snake them around into place. But if they don't fit, I could just attach them in a different location and solder the leads into place.
Thoughts? Is it a good idea? Or would it be better to just heat up the glue, remove everything, then glue it back into place?
