ow81
Hi,
I fairly recently bought a Streamer, the Project Streambox S2, and find the device is simply not up to the job for playing my large FLAC collection (1-2TB). It just doesn't seem to have enough computing power and takes ages to display my files in the app when I initially turn it on, up to 4 or 5 minutes. It also struggles when I select a track from a different album often, it takes forever to load the new track.
Anyway I've been contemplating buying a Wiim Ultra for a while now but then I had an idea; my DAP a Hiby R3ii lets you set the 3.5mm jack output as a LO. So I've used a 3.5 to RCA cable to plug the DAP into my amp. Theres an app called Hiby music that enables you to control the DAP from a phone, you can browse through and select your music the app works really well with no lagging problems.
It seems to me that the sound is good from this arrangement, they do sell a dock that acts as a stand and has usb c for charging and usb dac and RCA sockets on the back for line out. But at nearly £200 I can't see the point in buying this I can just use cables to connect the Usb C and line out.
I know the R3ii is a fairly budget DAC which will affect things but it has dual es9219 DAC chips. Is there any reason that anyone can see why this set up would be worse for a sound point of view when compared to using a device like the Wiim, ignoring the specs of the devices but why the setup would be inferior? I don't think there is but would be interested to know.
