terpodion
I'm thinking of using two midrange drivers per side in the ever changing main speakers in the big, scary system that lives in my garage / workshop.
An Eminence Alpha 6A (6") and a Selenium 8PW-2 (8"). Why? first and foremost because I have them laying around and because my theory is to make that band more linear. The Alpha is hot in the 1.5 to 5kHz range and the 8PW-2 is hot below that. When I had the Alpha in the system by itself, it sounded very nasal, but I was using a cheap MCM Electronics passive crossover.
This is now a tri-amp system with a BGW 250D driving the midrange. An Ashley active crossover will allow me to experiment. The drivers will be time aligned as closely as humanly as possible, stacked vertically and spaced as closely as possible.
I can't find a lot of information on using dissimilar drivers in the same range in the same speaker. What little I can find says it's a bad idea. I'm skeptical. In any case, I bought a bunch of toggle switches from a Radio Shak going toes up so I'll be able to do comparisons by switching various drivers on and off.
